Create sections based on bounding box Dynamo
Hi all,
Is it possible to create sections based on min&max points of the boundingbox in Dynamo?
I’ve tried to visualise my problem in the image.
Hope you guys can help me!=)
I’ve found these links useful for creating section views, in my case it was for generic models but you should be able to manipulate them to work for you.
This link is from revitbeyondbim and this link is from a thread on this forum where @Dimitar_Venkov has a good workflow.
Since you want sections in two planes it will be best to see if you can get one orientation working then rotate the vector by 90 degrees in the correct plane
Thanks for your reply!!=)
