Set Curve of SectionLine
Hello Dynamo Friends :slight_smile:
I want to set the extents/markers of sectionlines.
As example I want to set it to the half of it´s length.
I can get the curve with @Alban_de_Chasteigner ´s Element Location Curve node.
But I´m struggling at setting an new curve to the sectionline:
Happy about any advice :slight_smile:
items = UnwrapElement(IN[0]) if isinstance(IN[0],list) else [UnwrapElement(IN[0])]
curve = UnwrapElement(IN[1])
for item in items:
	doc=item.Document
	viewSection = doc.GetElement(ElementId(item.Id.IntegerValue + 1))
	newshape=viewSection.GetCropRegionShapeManager().SetCropShape(curve)
Hi!
Do you want to bring the section heads to the middle of their line?
Reading the error message, it looks like you’re passing it a curve, but you need a curve loop (silly but it allows the stepped sections).
Create a new curve loop, and append your curve and the error should be resolved. You may need to convert the curve to a Revit curve first though.
Hello Jacob,
This gives me this error, Error creating an arc!
curve = UnwrapElement(IN[0])
loop=CurveLoop()
loop.Append(curve.ToRevitType())
Can you post a rvt and you dyn?
It looks like you might be passing a dynamo arc instead of a Revit one.
You are right that was just a problem with the curve.
Next error for SetCropShape:
Now I´m asking myselfe if this is even right to get the sectionview from the section line and set the cropshape to the sectionview…
app = uiapp.Application
loop=CurveLoop()
for item in items:
	doc=item.Document
	newshape = viewSection.GetCropRegionShapeManager().SetCropShape(loop)
OUT = loop,viewSection
Looks like not… I’ll try and have a look later tonight, or sometime next week.
CropShape needs a CurveLoop that contains at least 4 curves. And I don’t think that section line is editable. I had searched for an API-Method but I could not find.
Thanks for your help.
Alban is writing about Section Markers in his Set.Location node:
loc = element.Location
if loc:
##Section Marker and ReferenceElevationMarker(Doesn't work for ReferenceElevationMarker)
if ElementId(BuiltInCategory.OST_Viewers) == element.Category.Id :
	viewSection = doc.GetElement(ElementId(element.Id.IntegerValue + 1))
	loca = viewSection.Origin
ElementTransformUtils.MoveElement(doc,element.Id,location.ToRevitType()-loca)
So maybe the marker itselfe can be moved along the section line?
Or is this only about moving the whole sectionline?
