I want to get the min and max coordinates and the view depth of a section view thus the reverse of this node.
thnks
thnks
Hmm… so here’s my go… Have a play and see if it works for you?
I don’t think you can extract a bounding box from a section (and anyway it would be axis aligned?)
I also don’t think you can extract the ‘location’ to get the coordinate system.
So my solution is a geometric one, to get (what I think you’re wanting) as outputs… I got the crop box and extruded it by the view depth, it seems to work even if the section has crop view unchecked.
Hope that’s of interest,
Mark
Edit: You’ll need the MEPover package
Hmmm… Well, how about running the element geometry through a Does Intersect Node?
Yes got it working, the Geometry.DoesIntersect node had i already found but i was checking it with a solid so all the elements i want to check are intersecting.
so i plug Solid.ThinShell after the Curve.ExtrudeAsSolid and feed this one into the Geometry.DoesIntersect @Mark.Ackerley thanks again.
Nice idea, I’ll try and remember that one
