Get Project Parameters Name through Python Issue
I’ve been tring to get the name of the project parameters through python and the API but it keeps getting me the error message: The managed object is not valid.
Here is the code:
res = []
iterador = doc.ParameterBindings.ForwardIterator()
while iterador.MoveNext():
	res.append(iterador.Key)
OUT = [a.Name for a in res]
Thanks for all your support
your code seems to work fine on my end, so i suspect is that you didnt load the correct assembly/method.
try replacing your importing part to this
# Import RevitAPI
clr.AddReference('RevitAPI')
EDIT: Is you didnt load in the revit api assembly :smiley:
and also your code can be shorten by just placing a “Name” property after the Key method like this:
res = []
	res.append(iterador.Key.Name)
OUT = res
I have run into this issue before specifically with ParameterBindings. I think the only way to solve this (temporarily) was to restart Dynamo and/or Revit. The code you have written is syntactically correct, but I think the error is out of your control.
@ramoon.bandeira, how about this one?
Thanks for your tip
I really missed the imports. The final code was:
res = []
OUT = res
