Get ProjectParameters with Python
Hello all,
Since I don’t have much experience with Python, I would like to ask your help for the following.
In Dynamo 2.6 I had a Python script that could retrieve the ProjectParamters in my project.
in Dynamo 2.16 (Revit 2023) I get an error with this same script. See image.
Who can help me solve this?
clr.AddReference(‘RevitAPI’)
params =
cats =
iterator = doc.ParameterBindings.ForwardIterator()
while iterator.MoveNext():
params.append(iterator.Key.Name)
thesecats =
for cat in iterator.Current.Categories:
thesecats.append(Revit.Elements.Category.ById(cat.Id.IntegerValue))
cats.append(thesecats)
OUT = (params,cats)
Try install package IronPython instead
(now you run Cpython)
Hi manhgt214,
Thank you for your response.
I have tried both IronPython2 and CPython3 and both to no avail.
Hey @Fernand77
Also for future reference, use the Preformatted text option when providing your code.
what error?
I tested your code, work on CPython
Check indentation level in loop.
clr.AddReference('RevitAPI')
params = []
cats = []
	thesecats = []
OUT = (params,cats)
Hi manhgt214,
I still get the message in my project.
In a new empty project, it works fine…
You can use: try except to ignore exception
params = []
cats = []
	thesecats = []
		try:
		except:
			pass
OUT = (params,cats)
