So i wanted to get all the parameter binding from the document and put them in the dict.
This code works when you run it once, but after that it wont work until you restart the entire project (lets say you changed something in python script, when you hit run after change it will throw an error).
dict = {}
map=doc.ParameterBindings
it=map.ForwardIterator()
it.Reset()
while(it.MoveNext()):
key=it.Key
item=it.Current
name=key.Name
dict[name]=[item,key]
i keep getting the “The managed object is not valid” on the row where i get the key.Name.
Any one has any idea where this error comes from?
