Set ProjectParamter with Loop
Hey Everyone,
i am pretty new to Dynamo and Python. I have the task to set project paramters for the current Document. I get the parameters from an excel file. So far so good. I managed to collect all the informations i needed in three lists. I wrote a little python script to set the parameters but it doesnt work like i want too. The Script writes in all elements the same value and i cant figure out why. I think its a loop problem but, i cant find the problem. Can anybody help?
PS: Sorry for my bad english.
i wrote a litte python script who looks like this:
# Phython-UnterstĂĽtzung aktivieren und DesignScript-Bibliothek laden
import sys
# import Revit API
clr.AddReference('RevitAPI')
# import Revit API UI
# import Revit Services
# get Revit's current Document file.
# get the current application
app = DocumentManager.Instance.CurrentUIApplication.Application
#get the user interface application
app = uiapp.Application
# Die Eingaben fĂĽr diesen Block werden in Form einer Liste in den IN-Variablen gespeichert.
elements = IN[0]
pnames = IN[1]
pvalues = IN[2]
for ele in UnwrapElement(elements):
	for pvalue in pvalues:
		for j in range(0,len(pnames)):
			p = ele.LookupParameter(pnames[j])
			p.Set(pvalue[j])
What i expect:
Set Paramters for every element right
What i get:
set for every element the same parameters.
Here is the python code for testing:
elements = [2131026,2131560,2132029]
pnames = ["lfNr","BT/Etage","Raum / Bereich","DN","Nennweite Q3 = m³/h","AKS","Zähler Nr.","Stand"]
pvalues = [
    ["1","AU1", "WWB Küche Sanitärzentrale A.-2.TE.020","25","6,3","AU2_014_SAN_ZAE_WZ005","…","0,00"],
    ["2","AU2","Fettabscheider Sanitärzentrale A.-2.TE.020","15","2,5","AU2_014_SAN_ZAE_WZ006","…","0,00"],
    ["4","AU4","Enthärtungsanlage Küche Sanitärzentrale A.-2.TE.020","25","6,3","AU2_014_SAN_ZAE_WZ007","…","0,00"],
for ele in elements:
    print(ele , "-----------------------------------------------------------------------------------")
        #print(pValue)
            #print(j)
            #print(ele)
            pGet = pnames[j]
            pSet = pvalue[j]
            print(pGet)
            print(pSet)
            print("-----------------")
problem solved:
import sys
# import Revit API
elements = IN[0]
pnames = IN[1]
pvalues = IN[2]
for element, values in zip(UnwrapElement(elements),pvalues):
	for name, value in zip(pnames,values):
		p = element.LookupParameter(name)
		p.Set(value)
# Code unterhalb dieser Linie platzieren
# Weisen Sie Ihre Ausgabe der OUT-Variablen zu.
