Get Project parameters of link file python
Hello I got a code that gets the project parameters and their names, it works with current document but it does not work with links instances or documents because I get error:
  File "<string>", line 28, in <module>
AttributeError: 'NoneType' object has no attribute 'ParameterBindings
the code is this:
import System
clr.AddReference("RevitAPI")
inputdoc = UnwrapElement(IN[0])
if inputdoc == None:
elif inputdoc.GetType().ToString() == "Autodesk.Revit.DB.RevitLinkInstance":
	doc = inputdoc.GetLinkDocument()
elif inputdoc.GetType().ToString() == "Autodesk.Revit.DB.Document":
	doc = inputdoc
else: doc = None
names = []
elems = []
iterator = doc.ParameterBindings.ForwardIterator()
while iterator.MoveNext():
	names.append(iterator.Key.Name)
	elems.append(doc.GetElement(iterator.Key.Id))
OUT = names, elems
How come the linked doc does not have ParameterBindings attribute?
@ruben.romero it is working perfectly from my side, just a side note, why are you getting just the first parameter from your lists? I used the Links node from the Rhythm package as an input:
try using python code to get instance or document input
You appear to be inputting an object which is not returning either Autodesk.Revit.DB.RevitLinInstance or Autodesk.Revit.DB.Document. However without seeing what you are feeding in we can’t really identify where there error is.
