Python get parameter name list
Hi all,
I am trying to learn some python forcing my self to do some scripts. Using dynamo nodes, I am able to perform this action with no problems, but doing it in python it’s a complete different thing.
At the moment I am trying to retrieve parameters name associated to project informations but I keep getting a list of (I think) Revit Objects, not the parameter names.
Please check the image below
  1. This is the OUT variable from the python script
  2. This is the code
> import clr
> #Import Revit Nodes
> clr.AddReference("RevitNodes")
> import Revit
> clr.ImportExtensions(Revit.Elements)
> # Import RevitAPI
> clr.AddReference("RevitAPI")
> import Autodesk
> from Autodesk.Revit.DB import *
> # Import DocumentManager and TransactionManager
> clr.AddReference("RevitServices")
> from RevitServices.Persistence import DocumentManager
> doc = DocumentManager.Instance.CurrentDBDocument
> allProjParam = []
> collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_ProjectInformation).ToElements()
> for projPar in collector:
>     allProjParam.append(projPar.Parameters)
> OUT = allProjParam
From here I would like to have a list of all parameter names, not just revit objects, anyone knows how to? :slight_smile: THANKS
@Ernesto_Pellegrino try this way;
thanks @jean but it seems that .Parameters has no definition attribute :confused:
@Ernesto_Pellegrino Or just copy paste from here,
#Import Revit Nodes
# Import RevitAPI
allProjParam = []
    for parameter in projPar.Parameters:
        allProjParam.append(parameter.Definition.Name)
OUT = allProjParam
awesome! thanks @jean
I was trying to search “something to do that” with the dir() function but I didn’t see .Definition
:smiley:
have a great day!
