i am currently looking to obtain the geometry (faces/edges) of a conceptual mass, form/shading/glazing/floors, into Dynamo. i haven’t found a way to get the geometry of the glazing. I can get the element ID etc, but not the actual edges/faces.
i can manually select the glazing edges but this is not realistic when working with large complex building forms.
I have tried topology nodes / element.geometry / faces etc.,
I require this as i am looking to use the coordinates in other packages.
Thank you in advance,
Hi @Atkins14 ,
could you share a dummy file with your conceptual mass or drop some screenshots?
Hi!
Could you be more specific? Do you want to get geometry of a Curtain System applied to a mass face or a Divided Surface with panels? Or maybe the mass face itself?
Could you share a dummy file?
i am setting the glazing % of the mass via the energy settings (i.e. 40%) - and want to get this geometry into Dynamo. Attached are some screenshots of the revit model and what i am currently using to bring the geometry into Dynamo.
@Atkins14
those geometries are a little tricky to get indeed. Here’s how you can do it :
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
opt = Options()
faces = []
for i in IN[0]:
e = UnwrapElement(i)
ref = e.GetFaceReferences()[0]
r = doc.GetElement(ref)
f = r.GetGeometryObjectFromReference(ref).ToProtoType(True)
faces.append(f)
OUT = faces
@Mostafa_El_Ayoubi that worked a treat. thanks. The next thing is that the exterior walls are brought in as complete surface (no openings for the glazing surface). How could i extract the glazing geometry from the exterior wall geometry?
Thanks in advance,
@Atkins14 ,
I never found a way to access the exterior wall geometry with opening through the api. But here’s a little workaround … (same python code)
That worked a treat. Thanks very much.
