How do I import Dynamo geometry into Revit?
Hi.
I have tried everything. I do not know how to import my Dynamo mass model into Revit.
I have checked visibility settings, opened a mass model into the project and then opened Dynamo to run. Nothing seems to work. Show Mass Form and Floors is also active.
Please help.
Image of my nodes can be found here:
Image of the geometry:
Many thanks
I have managed to import the mass but it is very small! How do I make it bigger?
You can do that two ways.
1st. change units in the settings menu.
2nd use bigger values as input
@Marcel_Rijsmus Thank you. I changed the units in Edit Type.
But now I cannot make a curtain wall system for some reason
Imgur
Try making the changes for units in dynamo, not in Revit so it will scale up.
Curtain systems don’t like small surfaces.
Once your done, google “buildz zach kron”
Lots of things to explore on his blog.
Also, try making it a conceptual mass
Thank you for the advice. I have made it the right size but still can’t add curtain wall. How do I make it a conceptual mass?
Start a conceptual mass, then start Dynamo. Not before
