Genius Loci Documents Properties Not Recognizing Rythym Node
As the title suggests I am having issues with the nodes and I believe it may be due to different packages. The rythym node is producing Revit.Application.Document while the Genius Loci Node wants Autodesk.Revit.DB.Document.
Given this is my first real attempt at NWC export using the script flying around Iam unsure how to resolve this issue.
Can anyone point me in the right direction?
EDIT: I have updated all the nodes to the latest available as they had an error that they were created with an older version of Dynamo/packages
Hi @stacey.hennigL6B3T rhythm have a ndoe for convert to autodesk.revit.db.document
Thank you, this finished off the issue
