I have been trying to export floor areas to excel and it keeps inverting the floor areas. For example the floor area for second floor is assigned to ground floor and vice versa but the middle floor is assigned with the correct floor area
can you make a better screenshot?
zoom in until you can read the nodes, then click the camera button (right top)
if you set it up like this there is no correlation between floors and levels
one of the parameters from the floors is the level its been placed on.
if you derive your levels from the floors the list you get is in the same order
use element.parameters node to see what parameters are accessible from the floors
place the node right after all elements of category
let me try this and get back to you
so i just add this to my script or?
Let me try this as well
