Hi
I am trying to create levels in revit file from excel inputs. Only first and last levels are being created. What could be the problem?
Thanks in advance.
@abhijeetraje Please share your dyn or a link
Create Levels from Excel.dyn (23.0 KB)
Sorry. Should have attached this too. Attaching now.
@abhijeetraje Can you upload the Excel file as well?
String to number between the level by elevation and name node and the get parameter value by name node.
Edit: @Kulkul beat me to it.
Levels.xlsx (10.1 KB)
Here it is
Hey thanks… I checked this out and created levels without name which is happening. Only issue is to convert number to string. Is there a node for it?
@Kulkul Where do I get node Excel.readFromFile?
That’s the same node which your using the only difference is i showed you in Dynamo 1.3x version .
Hey Thanks… got it. Get evth as string and then convert the levels to numbers…
OK. Got it.
