Im am searching for a way to have square meters exported to excel to a particulair row depending on the level off the square meters.
An example when the square meters are on the 1st floor they need to be exported to row 20
but when the square meters are on the 2nd floor they need to be exported to row 21.
You can do this by getting the levels, sorting by elevation or whatever, getting the index of the level in question, add one to it, and then multiply that by 10.
It will get a little bit more complex to add the other levels if you want to use the same script. But basically you will need to enter some null values in the list to move the 2nd “row” down.
