When I run this, it only creates 1 pdf from the top of the FilenameToFilePaths list. How do I get it to use the full list? Thank you! (The Print PDF node is from GeniusLoci)
Maybe it has something to do with your lacing in the last node. But if that doesnt work maybe you could upload a revit file/ this dynamo file so we can take a look
It’s a lacing/list levels/structure issue. Use list levels @L1 for the FilePaths input.
@Nick_Boyts is rigth. The list levels must be @L1 but for the PrintSetting input.
The custom node is designed to work with as many views as filepaths and print settings : (see tooltips)
Thanks for your help guys!
