Exporting Summation of a schedule
Hello People,
I have a question. Is it possible to export a summation from a schedule (For example the sum of a flat TOP01= 100m² , TOP02=150m²,TOP03=120m²,…) to a parameter? Because i want to make a tag with the summation of the respective flat infront of an entrance door. (Maybe it works with dynamo, but i am a newbie in Dynamo)
Sorry for my english.
Would be nice if somone can help me. :slight_smile:
greets
Yes that would be a really good use for Dynamo!
You could start by trying to export your data in your schedules and getting the sum of those floor plans in Dynamo. Let me know if you need some help with that :slight_smile:
PS: This website is really useful to find new nodes which you might need
Hello Manuel,
first your english is really good, one less thing to worry about :slight_smile:
To be able to do that you don’t need a schedule but a shared parameter to store the result.
First, i have no idea what a flat is and im also guessing that it’s more complicated then the below example but i hope this an get you started
The example here is done with a the sum of all walls written to the doors.
Hello Daniel
Thank you for your answer! I’ll try the definition asap. :slight_smile:
Hello Daan
First thank you for your answer! :slight_smile:
Good to know. As before mentioned i have to get more into Dynamo :stuck_out_tongue:
But i try your advice :slight_smile:
