Hello all,
I am trying to edit revit schedule thought the dynamo, i wanna export the formula into the revit schedule, but i have no idea, how can do this?
Thanks you
Hello all,
Thanks you
You can calculate the value and write it to the Comments parameter of the Window element using Element.SetParameterByName
However, I would have not used Dynamo and just handled it with a Calculated Value in Revit (assuming x and y are also associated with the element)
Thank you VIKRAM :), i can export my formula to revit schedule!!!
