I’ve been reading up on the various discussions around exporting schedules from Revit into Excel. The bumblebee primer seems to be rather perfect, but I’m running into some troubles (likely due to lack of dynamo knowledge).
The attached screen shot shows my attempt to use the bumblebee data node to export the material schedule into an excel doc. Next step will be to format, but first can’t even get it to write…
My assumptions are the hiccups are happening in either (1) the code block for “data” – I don’t understand what is happening here. Or, (2) that the “BB Data” node is looking under “sheets” instead of in the “schedules/quantities” tab. (this schedule is not placed on a sheet)
Any wisdom/advice/tips would be appreciated. Thank you.
