Export geometry Dynamo to Mass Revit
@LifeisMyLove
Follow these steps …
  1. Open a Conceptual Mass family template in Revit
  2. Launch Dynamo, add Import Instance.ByGeometry node to the end of your graph and run.
  3. The geometry is imported to the Revit Conceptual Mass environment.
  4. Load this family into your project.
  5. You should now be able to select faces and create a Curtain System
