I’m running through a major problem that I really need help with. I’ve seen many tutorials on how to “read” excel data into dynamo, however I am not able to perform the operation.
I have written a script in the past, tested it on my machine for it to read the data and it didn’t work. I sent the same script to my colleague, he did in in his machine, and it worked without a problem.
Somebody told me to try using the Bumblebee package. Tried it and it didn’t work either. I am not sure if this is a problem with Dynamo per se, or Excel. My gut feeling is that there is something wrong with Excel since when I try to create tables using ETABS, I’m also having issues (which is separate from this one). I’m using Dynamo 1.2 / Revit 2016, and Excel 2010 32-bit.
I’ve attached the files I’m attempting to perform this operation with no success. I’m using the files from dynamobim advanced tutorial - unit 4 excel read part 1.
Any help on this would be greatly appreciated. I’ve exhausted all resources, and don’t seem to find a solution to this problem.
Thank you!
