What was your Dynamo version before installing 0.7.2?
If it was 0.7.1, then you have to un-install that manually before installing 0.7.2. We were having one know issue in upgrade as we have change a lot in 0.7.2 which is going to be same for all future Releases. That is the reason our new installer is just 27MB and it will not install ASM stuff now.
After installing Dynamo 7.2, when attempting to place a node I get a blank box appear rather than the node’s actual appear. See attached image. Even loading the tutorial files, I just get empty boxes, with strings appearing but nothing else.
I have repaired Revit, attempted installing 7.0, and 7.1 and still no solution on any of the Revit platforms. 2013, 2014, 2015.
