Element.IsTagged 'RoomTag' object has no attribute 'TaggedLocalElementId'
Hi, this script was working really well to tag things that wernt tag. However now I’ve started to get this issue below. I pulled the guys of the node out to show the error. Any suggestions? :thinking: :slight_smile:
Can you take a screenshot of the python code too?
Hard to solve without that :slight_smile:
I ended up just deleting the room tags and tagging from scratch to get around it. The codes below if your interested :slight_smile:
If your keen on a python challenge some help with this would be awesome! :rofl:
#python nodes in dynamo 1.0
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
elt = []
for i in IN[0]:
	elt.append(UnwrapElement(i))
ids, tags = [], []
# Start Transaction
#TransactionManager.Instance.EnsureInTransaction(doc)
for i in elt:
	if i.TaggedLocalElementId.IntegerValue != -1:
		ids.append(i.TaggedLocalElementId)
		tags.append(i)
		continue
# End Transaction
#TransactionManager.Instance.TransactionTaskDone()
OUT = ids, tags
On line 40 of the script, the element you’re calling .TaggedLocalElementId on doesn’t have that property. This is because it’s a roomtag which doesn’t have this property. Read the description of the revit api (link below) for more information.
https://www.revitapidocs.com/2020/e52073e2-9d98-6fb5-eb43-288cf9ed2e28.htm
