Hi. I’m trying to change or place a title block family in multiple background documents. Trying to combine a couple of nodes together to do it. Would anyone be able to complete it or is it much more complex?
All Elements of Types in Document with FamilyInstance.SetType can get the last instance to set
clr.AddReference('RevitAPI')
inputdocs = UnwrapElement(IN[0]) if isinstance(IN[0],list) else [UnwrapElement(IN[0])]
faminsts = UnwrapElement(IN[1])
famsymb = UnwrapElement(IN[2])
booleans = []
counter = 0
for inputdoc in inputdocs :
if inputdoc == None:
elif inputdoc.GetType().ToString() == "Autodesk.Revit.DB.Document":
doc = inputdoc
elif inputdoc.GetType().ToString() == "Autodesk.Revit.DB.RevitLinkInstance":
doc = inputdoc.GetLinkDocument()
else: doc = None
for item in faminsts:
try:
item.Symbol = famsymb[counter]
booleans.append(True)
except:
booleans.append(False)
counter += 1
OUT = (faminsts,booleans)
Or would using Family.InstanceByPointinView be easier?
Got this error though “Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed.
File “”, line 31, in
Exception: The input argument “document” of function `anonymous-namespace’::Transaction_constructor or one item in the collection is null at line 97 of file d:\ship\2019_px64\source\revit\revitdbapi\gensrc\APIUndoTransactionProxy.cpp.
Parameter name: document”
points = UnwrapElement(IN[0])
famtype = UnwrapElement(IN[1])
lvl = UnwrapElement(IN[2])
elementlist = list()
counter = 0
doc = inputdoc
else: doc = None
# make sure familysymbol is active
for point in points:
newobj = doc.Create.NewFamilyInstance(point.ToXyz(),famtype,lvl)
elementlist.append(newobj.ToDSType(False))
OUT = elementlist
