Tagging rooms - Python explanation required of 'ViewPlan is not Iterable'
Hi there,
I was having trouble getting the ‘Create Annotation Tag’ to place a room tag. I did a bit of hunting and found in the comments section of the nodes web-page (http://archi-lab.net/element-tagging-with-dynamo/) that room tags are not classed as an annotation category, and some Python code was posted as a solution.
I have copied the code over (annoyingly time consuming) but I have run into the following errors.
Tag%20rooms%20python%20Error
Can anyone explain why it is not taking the view input, and what it means by ‘not iterable’?
The code is:
# Import Element wrapper extension methods
# Import geometry conversion extension methods
#Import Documentmanager and TransactionManager
app = uiapp.Application
# Import RevitAPI
clr.AddReference("RevitAPI")
#The inputs to this node will be stored as a list in the IN variable
dataEnteringNode = IN
rooms = UnwrapElement(IN[0])
views = UnwrapElement(IN[1])
familyType = UnwrapElement(IN[2])
runMe = (IN[3])
#"start" the transaction
test = []
if runMe:
    roomTags = []
    for room, view in zip(rooms, views):
	    roomId = LinkeElementId(room.Id)
	    bbox = view.CropBox
	    XYZLocation = (bbox.Max + bbox.Min) / 2.0
	    location = Autodesk.Revit.DB.UV(XYZLocation.X + 0.2, XYZLocation.Y - 5.6)
	    roomTag = doc.Create.NewRoomTag(RoomId, location, view.Id)
	    roomTag.RoomTagType = familyType
	    roomTags.append(roomTag)
    roomTags = "Run Me set to False"
# "End" the transaction
#Assign your output to the OUT variable
OUT = roomTags
File download: Tag just bathrooms.dyn (20.5 KB)
Hello. When the error is something “is not Iterable” it basically means you are treating some single object as a list.
In this script, it is expecting a list of views as the input 1. An easy solution is to just use a List.Create using the view from Document.ActiveViewFromCurrentDocument as the only input and then connect to the Python node.
This is your issue:
You’re saying “for each pair, room and view, in their respective lists of rooms and views…” This would require matching list lengths with each room having a paired view. If you only have a single view that is going to be used for all rooms you would just use for room in rooms: and then call the same view for each one.
