I don’t seem to be able to get anything out of it
Looks like you have planar shape floors. Try using “Springs.Collector.Element.Sketch” node from spring nodes package.
@Daniel_Hurtubise Seems like the issue is specific to the geometry of your floor element
Seems to work with (Sub Element) modified floors
Able to extract geometry if the corners aren’t filleted (rounded).
A workaround would be to approximate the curve with line segments.
This issue submitted on github by @Daniel_Hurtubise
