Hi Team,
Does anyone have an alternative node to use than that found in the Genius Loci Package
“Element Change Level”
I ask cause i am getting some unexpected results from the node.
To explain further i will explain my process;
- Move all elements to Temp level.
- Move Original Level to new position
- Change element back to original level
But what is happening is the elements when i run the below code are moving a little bit and not associating themselves with the new level, but no error messages are given in dynamo.
Hi @m.fasher,
Make sure you are using an updated version of the Genius Loci package.
What types of items do not change levels? Items with a host ?
Can you share your Revit file (by private message if the data is sensitive) ?
Hi Max,
The OOTB All Elements at Level node doesn’t collect the pipes, ducts, cable trays, beams…
Instead, use the All Elements at Level + to change the level of pipes and pipe fittings at once.
Thanks Alban,
This now works prefect as intended.
it Dosent Work just give me NULLs
The code of the Element Change Level node was written using the Python 2.7 engine.
So the DynamoIronPython2.7 package version 2.5 must also be installed for the custom node to run, as explained in the package description.
