Re-assing a level without moving the elements
We are currently working on a project wich contains many double levels (for example: 00_ground floor and 00_ground floor bottom). We want to remain just one level for each floor.
Is there a dynamo script to reassing element from one level to another level without moving the elements?
Kind regards,
Bjorn Vrenken
Hi @b.vrenken,
Use the Element Change Level node from the Genius Loci package.
This custom node works with most of the categories.
Hello @Alban_de_Chasteigner
The script does work real good! But, I want to reassing all the categories for a level at once and not by type. So I want to reassing everything from level A to level B at once? Maybe you know how I can do that? I am just a beginner at Dynamo and I can’t find the right anwser online.
I also get a notification that I need to edit in edit model, because it are all model groups. Maybe you know something for that to? I’ve read online that this is very hard to do, because Revit does not allow it?
Kind regards, Bjorn
There is no API access to editing members in a group, so you may need to ungrounded things or recreate group instances.
Use Levels, All Elements at Level+ and then Element Change Level nodes.
See the answer in the post above.
