Hi gang,
Extremely new to Dynamo, please bear with me .
I’m looking for this node here called Element.level but cant seem to find it.
Any help is appreciated.
Kind regards,
LL
hi @liamlow13 , This custom node is part of the GeniusLoci packages.
you can use @openmep to do it also, it will hander more case can’t get level elevation with normal case :
thank you @chuongmep. i appreciate this
thanks @Mike.Buttery . didnt even know this existed. will take a closer look
Apprecaite it @sjafarali75 . i’ll get tht downloaded.
hi @sjafarali75 , i was looking to download this via dynamo from revit, this popped up
Is this normal ? it mentioned instability. but this is also the only genius loci tht popped up in the search results.
Yes. The author publishes from a build which doesn’t indicate if it is coming from Revit, Civil 3D or Dynamo Core so we get that popup.
thanks @jacob.small !
