When running a selected Dynamo Graph from Dynamo Player, is there a way to inform the user of successful run/finish of a Dynamo Graph… perhaps with some Info shown to the user?
it does?
Before run
While running
After run
Run complete with errors. This one could use some work because it will say there was a problem if the graph completed, did not complete or somewhat completed. Some nodes just error. I try to make it a point to fix any and all errors so this will only show if a real error takes place. If I cannot stop the error I dont like to use the player.
If you are running Revit 2018.2 or newer then you can change parameters from the player and see outputs. If you change the name of a watch node it will show once the script has ran. In this case it passes some pre scripted text to the uses to let them know if there are duplicates.
Hope this helps,
