Is there any way to report errors when running a graph in Dynamo Player? When running directly from Dynamo I can see the yellow warning icons and figure out why there is an issue. If I run a graph from the player, it will report that there are issues, but opening the graph post-run effectively resets it, requiring a second run.
I’m thinking the new package from DesignTech (@solamour) could have some nodes to help with this. Although at first, it isn’t really doing what I want yet.
The idea would be to find out what nodes are erroring out and output those to a watch node as a string.
Another option, for now, would be to monitor select important nodes for null and output that. (Way more effort though)
Ok, so red is error state and not yellow. I bet there is a way to track for yellow though. @solamour? I bet we could add a node for “IsInWarningState”.
http://dynamods.github.io/DynamoAPI/Dynamo_Graph_Nodes/State/#state
any update? did it get depreciated ?
