Dynamo to word file?
hey, i know its a stupid thing to ask, bur i want a prefilled word document to fill up project data in its blank spaces (like project name, specific project costs from revit schedule, etc) which i wanna import automatically using dynamo. is that possible?
i cannot find such an option but i know you awesome guys might suggest some solution to this! Thanks in advance.
You could try first exporting to Excel and then to Word using python.
yeah @johanboo that might work but it will become two step process, or are you suggesting i should export to excel and then to word using python within dynamo ?
As I recall you can directly read and write rtf files with Dynamo (including formatting), which can be read by word without issue. Just means you have to change from .doc to .rtf.
I used to do the prep work for all my field reports this way. Read the template, last report’s stuff to follow up on, weather on site, and a few other external bits. Then emailed myself the file as Pages on iOS reads that format just as well, and then would add new photos via camera and notes by voice to text as I walked the site. Got back to the office, proof read it and would have it sent out inside an hour.
Hello
another solution using Microsoft.Office.Interop.Word
import sys
import System
clr.AddReference("Microsoft.Office.Interop.Word")
import Microsoft.Office.Interop.Word as Word
clr.AddReference("System.Runtime.InteropServices")
import System.Runtime.InteropServices
def find_replace(objRng, search_txt, replce_txt):
	missing = System.Type.Missing
	replaceAll = Word.WdReplace.wdReplaceAll
	objRng.Find.Execute(
	search_txt, # search text
	True, # match case
	missing, # match whole word
	missing, # match wildcards
	missing, # match sounds like
	missing, # match all word forms
	True, # forward?
	Word.WdFindWrap.wdFindContinue, # wrap enum
	missing, # format?
	replce_txt, # replace with
	replaceAll, # replace enum
	missing, # match Kashida (arabic letters)
	missing, # diatrics?
	missing, # match other Arabic letters
	missing # support right to left
def doc_replace_text(source_filename, tokens, values):
	global errors
	word_application = Word.ApplicationClass()
	word_application.visible = True
	document = word_application.Documents.Open(source_filename)
	#Find and Replace Process
	for _find, _replace in zip(tokens,values):
		for myStoryRange  in document.StoryRanges:
			find_replace(myStoryRange , _find, _replace)
			try:
				while myStoryRange.NextStoryRange is not  None:
					q = myStoryRange.NextStoryRange
					find_replace(q, _find, _replace)
			except:
				import traceback
				errors.append(traceback.format_exc())
			#Find and replace in TextBox(shapes)
			try:
				for shape in document.Shapes:
					initialText = shape.TextFrame
					if initialText.HasText:
						rangeobj = initialText.TextRange
						find_replace(rangeobj, _find, _replace)
			except:
				import traceback
filename = IN[0]
tokens = IN[1]
values = IN[2]
errors = []
word_application.Quit()
word_application = None
doc_replace_text(filename, tokens, values)
OUT = errors
wow, this seems like a solution to me :heart_eyes: :heart_eyes:
that is an efficient way, amazing logics :ok_hand:
I am using your code @c.poupin , and it is working fine, except for one thing. When i put a string with more than 255 characters it crash and return an error about the excess of length of the string.
I am trying to solve but i can’t fix it. Anybody know how to solve it? Thanks
Can you post a screenshot of the error? It’s the path’s length of the file?
@c.poupin
Is because the string has more than 255 characters, and I want to write more than 255 characters by string.
The errror: Advertencia: IronPythonEvaluator.Error en la operación EvaluateIronPythonScript.
File “”, line 71, in
File “”, line 43, in doc_replace_text
File “”, line 16, in find_replace
EnvironmentError: System.Runtime.InteropServices.COMException (0x800A16DE): El parámetro de la cadena es demasiado largo.
en Microsoft.Scripting.Interpreter.MethodInfoCallInstruction.InvokeInstance(Object instance, Object args)
en Microsoft.Scripting.Interpreter.DynamicInstructionN.Run(InterpretedFrame frame)
en Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
en Microsoft.Scripting.Interpreter.LightLambda.Run4[T0,T1,T2,T3,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3)
en IronPython.Compiler.PythonCallTargets.OriginalCallTarget3(PythonFunction function, Object arg0, Object arg1, Object arg2)
en System.Dynamic.UpdateDelegates.UpdateAndExecute5[T0,T1,T2,T3,T4,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4)
en Microsoft.Scripting.Interpreter.DynamicInstruction6.Run(InterpretedFrame frame) en Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame) en Microsoft.Scripting.Interpreter.LightLambda.Run4[T0,T1,T2,T3,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3) en IronPython.Compiler.PythonCallTargets.OriginalCallTarget3(PythonFunction function, Object arg0, Object arg1, Object arg2) en System.Dynamic.UpdateDelegates.UpdateAndExecute5[T0,T1,T2,T3,T4,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4) en Microsoft.Scripting.Interpreter.DynamicInstruction6.Run(InterpretedFrame frame)
en Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
en IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx)
en Microsoft.Scripting.Hosting.ScriptSource.Execute(ScriptScope scope)
en DSIronPython.IronPythonEvaluator.EvaluateIronPythonScript(String code, IList bindingNames, IList bindingValues)
try this method
import sys
import System
import time
	if len(replce_txt) < 250:
		True, # match case
		True, # forward?
		missing, # format?
		i =0
		flag = True
		while flag and i < 20: # prevent infiniteloop
			copyRange = objRng.Duplicate
			flag = copyRange.Find.Execute(
			missing, # match case
			missing, # forward?
			missing, # wrap enum
			missing, # format?
			missing, # replace with
			missing, # replace enum
			if not flag:
				break
				copyRange.Text = replce_txt
			i += 1
	global errors
	#time.sleep(2)
			try:
			except:
				import traceback
			try:
			except:
				import traceback
filename = IN[0]
tokens = IN[1]
values = IN[2]
errors = []
OUT = errors
Perfect. Working. Great the loop inside de function! :slight_smile:
@c.poupin a query if I wanted to edit more than a single word how could I do it, what am I doing wrong
Hello @Christhian
try like this with this code
As always thank you very much, sometimes the solution is simple.
@c.poupin I apologize that there will not be a new thread for this question but if I wanted to change several words at the same time, would it be this way?
just add a for loop
import sys
import System
import time
		True, # match case
		True, # forward?
		missing, # format?
		i =0
		flag = True
			missing, # forward?
			missing, # format?
			if not flag:
				break
			i += 1
	global errors
	#time.sleep(2)
			try:
			except:
				import traceback
			try:
			except:
				import traceback
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lst_filenames = toList(IN[0])
tokens = IN[1]
values = IN[2]
errors = []
for filename in lst_filenames:
OUT = errors
As always thank you very much @c.poupin , you make it look so simple
Hello @c.poupin , I tried using your python script in dynamo but it can’t read my Word document. Do you have experience with the following issue/warning?
"FileNotFoundException: Unable to find assembly ‘Microsoft.Office.Interop.Word’
I can’t find a solution for this issue. I’m new to Dynamo and have no experience with python.
Sorry for reviving this topic…
Thanks in advance.
This may be a shot in the dark… But I’ve found quite a few things don’t work in C-Python.
Try changing your node back to Iron Python and see if that helps.
