Also looks like another possible MSOffice update breaking their interop. Try the online repair tool which you can find via google search.
@Alien That was the solution, thanks a lot!
Code updated for Net Core 8 compatibility (with IronPython 2 or 3)
# import sys
import System
import time
clr.AddReference("System.Runtime.InteropServices")
import System.Runtime.InteropServices
class WordlEnum:
values Enum from API Interop Mircrosoft Doc , to avoid import lib in clr for Enum
Word_WdReplace_wdReplaceAll = 2
Word_WdReplace_wdReplaceNone = 0
Word_WdReplace_wdReplaceOne = 1
Word_WdFindWrap_wdFindContinue = 1
def find_replace(objRng, search_txt, replce_txt):
# missing = System.Type.Missing
missing = None
if len(replce_txt) < 250:
objRng.Find.Execute(
search_txt, # search text
True, # match case
missing, # match whole word
missing, # match wildcards
missing, # match sounds like
missing, # match all word forms
True, # forward?
WordlEnum.Word_WdFindWrap_wdFindContinue, # wrap enum
missing, # format?
replce_txt, # replace with
WordlEnum.Word_WdReplace_wdReplaceAll, # replace enum
missing, # match Kashida (arabic letters)
missing, # diatrics?
missing, # match other Arabic letters
missing # support right to left
i =0
flag = True
while flag and i < 20: # prevent infiniteloop
copyRange = objRng.Duplicate
flag = copyRange.Find.Execute(
search_txt, # search text)
missing, # match case
missing, # forward?
missing, # wrap enum
missing, # format?
missing, # replace with
missing, # replace enum
if not flag:
break
copyRange.Text = replce_txt
i += 1
def doc_replace_text(source_filename, tokens, values):
global errors
# word_application = Word.ApplicationClass()
word_application = System.Activator.CreateInstance(System.Type.GetTypeFromProgID("Word.Application", True))
word_application.visible = True
document = word_application.Documents.Open(source_filename)
#time.sleep(2)
#Find and Replace Process
for _find, _replace in zip(tokens,values):
for myStoryRange in document.StoryRanges:
find_replace(myStoryRange , _find, _replace)
try:
while myStoryRange.NextStoryRange is not None:
q = myStoryRange.NextStoryRange
find_replace(q, _find, _replace)
except:
import traceback
errors.append(traceback.format_exc())
#Find and replace in TextBox(shapes)
try:
for shape in document.Shapes:
initialText = shape.TextFrame
if initialText.HasText:
rangeobj = initialText.TextRange
find_replace(rangeobj, _find, _replace)
except:
import traceback
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lst_filenames = toList(IN[0])
tokens = IN[1]
values = IN[2]
errors = []
word_application.Quit()
word_application = None
for filename in lst_filenames:
doc_replace_text(filename, tokens, values)
OUT = errors
import sys
import System
import time
class WordlEnum:
missing = None
True, # match case
True, # forward?
missing, # format?
i =0
flag = True
missing, # forward?
missing, # format?
if not flag:
break
i += 1
global errors
#time.sleep(2)
try:
except:
import traceback
try:
except:
import traceback
tokens = IN[1]
values = IN[2]
errors = []
OUT = errors
