I have a couple of questions
- how did you generate the Clash sphere schedule in Revit?
- there are some errors that I have encountered with the script:
a. I have this corrected with the settings but it is still shows as an error
a.
what could I adjust ?
another error i encountered is this
The first warning is because the Clash name parameter isn’t set up to hold strings; likely built for numbers instead. Delete the parameter and rebuild it for text.
The second warning can be ignored.
I was able to change it but when i ran it warnings still appear and theres no clash sphere detected in the model and the clash schedule just like in the video is nowhere to be found. is the clash schedule a separate script?
You need to wire in the B and C inputs.
