Good morning. Here is where i start to have errors.
KİRİŞ.dyn (72.3 KB)
What is the output of the List.FilterByBoolMask? I don’t have your project so I can’t reproduce or do much more than guess…
If it’s the lines for the ‘beams from CAD’ workflow you’ve been working on (my guess based on what we’re seeing), then the only solution will be to move into another method of generating the groups. This is because there is an issue with zero volume (no Z height) bounding boxes which was introduced fairly recently, that may be resolved in 2023.1.2 but I am not sure. Worth updating to confirm.
This is another one for columns. It was workin with another CAD file in revit 2023 but not workin with current CAD file. Could you check the files out please that i added below.
kat1-5.dwg (77.4 KB)
Betonarme.rvt (5.3 MB)
KİRİŞ.dyn (72.3 KB)
Hi probably we should close this topic or the other…so we dont have duplicate post. or merge them…
This topic about why not the scripts are not work in revit 2023 while they are working in revit 2022.
What version of Revit 2023 are you in? Make sure you’re in 2023.1.2.
My version is 23.0.11.19
I start to think go back Revit 2022 if i can’t solve this issue.
If I am not mistaken, that’s predates the second hotfix from August of 2022 (so 12 months ago), so you’re missing updates for both functionality and security.
Update Revit 2023 and try again.
I installed monocle package . As an information It fixed a few mistakes but not all.
