Trouble with Dynamo Script
Hi there,
I’m not sure why, but I seem to be struggling with making this script work with Revit 2017? Can someone please help me with this? What am I doing wrong? Are the Dynamo scripts outdated?
Still having trouble uploading the files here, but I’ll reply with the link below.
Please help as I am SUPER worried!
TYA
Hi @taustin
Which script your talking here? Drop your script here.
@Kulkul
Here you go, brother: https://www.dropbox.com/sh/uw06jevkc4scu3o/AADZNrjMbvB0NSPlQVFU8Na0a?dl=0
Basically, I do not know why, I cannot seem to make this script work in 2017 mainly bc its slightly outdated.
@taustin Try this file Issue - Point-Adjustable Stadium Template.dyn (73.5 KB)
I have fixed it.
Arrrghhh! I still cannot get it to work!
I have attached pics below. I can see the lines, but there are a ton of errors.
Even the families are not showing up in revit.
@Kulkul
Did the objects show up in Revit for you?
@taustin That’s because that script is quite old. There are many node changes. You need to update the script. I would suggest you first study the functions of each nodes and start creating on your own stadium.
ok :frowning:
