Hello ![]()
When I “create” (example: bridge in Dynamo) and I select element from Revit to create that bridge, how to keep bridge in Revit when I close Dynamo?
Hello ![]()
You’ll have to search the forum for more specific examples, but geometry in Dynamo does not automatically get converted to Revit geometry. You either need to place families to construct the bridge or use one of the other methods to convert the Dynamo geometry into Revit elements.
The blue objects are just temporary graphics. You need to create an object in Revit in order for it to stay there. We can’t give you any more help without seeing your graph.
