Dynamo Player output
Hello Dynamo Community!
I have now tried in many scripts to set a node as output in Dynamo player but it never did anything.
Here is an actual example, i want to have the watch node as output in Dynamo Player.
But nothing there in the player.
Am i doing anything wrong? I would like to let the user select a list entry.
Thanks for any help! :slight_smile:
I would recommend you to use Data-Shapes UI++.
If you want to add something to Dynamo-Player as Input, you should right click on node before Watch node. From which node are coming these datas to Watch node?
It´s a family Name node and it is automatically set to output when i set the watch node as output
Ok, thanks i never had the time to look up datashapes, but i will do it now!
There is a YouTube video from @GavinNicholls, you can learn it and create your own UI.
Perfect, will learn and try it in the evening :slight_smile:
Rename the Watch node anything except “Watch”
Oooohhh and how should someone know that :smiley:
Works great, thank you tradelie!
you are so good
