Watch node in Dynamo Player
Hi, all.
I want to show the dynamo script results using ‘Watch node’.
but the ‘watch node’ didn’t show up in the Dynamo player.
I already checked ‘Show Labels’ and save it.
Even though I save this file, when I open this script in dynamo player, the watch node cannot show up.
Did you have a similar problem? or do you have any other ideas to show the results?
Thank you.
I think, you only have to change the name of the watch node
@Johannes_Meiners
Oh! I didn’t know that.
It is really simple thing, haha.
Thank you!
On top of that I have another question: Could I make the List that I see in Dynamo Player to zoom on the specific element I click on (as watch does in dynamo workspace) in Revit?
Hello, I have the same problem in Dynamo 2.03. I changed the name of my watch node from the default “watch” as per the advice above. The node is set like this:
nodesettings
what’s going on?
You should put an Output node after the watch node. You find it here:
I tried adding that Output node after the watch node and I still get the same result as @MuirEng
