Script Errors in Dynamo Player Revit 2017 But Not in Dynamo
Is there a way to see what errors were encountered in the script when run in the Dynamo Player?
The script runs clean in Dynamo 1.3.2.2480 but when I run it in the Dynamo Player it looks like it runs as it should be kicks back an error.
Any things that need to be done to the scripts differently than when run in Dynamo? Was wondering about things like Transaction end?
Any thoughts?
Make sure you’re running the graph from the same location. It’s possible Dynamo Player is looking at an outdated file. Try clicking the Edit button in Player then running the graph in that Dynamo session. I believe that should give you the same outcome as running the script directly from Player.
