Dynamo .OBJ Export File Format
I want to extract the wall models I created in Revit in .OBJ format.
I use the “Mesh Toolkit” package to get the walls as a solid model, then convert it to a mesh surface and then try to export it in .OBJ format with export.
But I can’t get an .OBJ file with all the model elements.
Is it possible to merge parts separated as mesh? Or is it possible to assemble the wall elements as a single piece?
The screenshot is attached in the appendix.
Thanks.
Hi @Tarcok,
Flatten your list of solids after Element.Solids node and use Solid.ByUnion node before Mesh.ByGeometry node.
Thank you very much for your help.
I missed a little detail (:slight_smile:
Tolga
