Dynamo not working properly in Revit 2025
I am facing an issue on Dynamo while working in Revit 2024. I am only able to access the nodes through the library. Searching using mouse right click and searching in Library searching option is also not working. For Revit 2023 it’s working fine.
What should i do to resolve this issue?
Likely an add-in conflict with Revit or a package conflict in Dynamo.
  • Disable all Revit add-ins and check if the issue repeats.
    • If not, narrow down which of the add-ins causes it by enabling them in small groups until it repeats.
    • If so, disable all Dynamo packages and check if the issue repeats.
      • If not, enable them in small groups until it repeats. Be sure to restart Revit at each check as ‘initial loading’ from package manager or otherwise enabling will not trigger the issue.
    • If so, restart the CPU, recreate the issue with NO revit add-ins and NO Dynamo customizations, grab your Revit journal, Dynamo log, and a screen recording showing the issue and post here.
Alternatively you can reach out to my colleagues in support via the accounts portal at Manage.Autodesk.com - they’re apt to direct you to try each of the above.
