Hi, My version of dynamo have a screen issue (the interface of dynamo workplace).
is there anyone have a solution ??
Usually a sign of a Revit add-in which is conflicting with Dynamo. Restart the CPU, launch Revit, start a new rvt file, open Dynamo, open a graph and confirm the issue, then force quit Revit.
Then disable alll Revit add-ins.
Launch Revit again, start a new rvt file, open Dynamo, open a graph and confirm the issue doesn’t persist, and force quit Revit.
Grab the two Revit journals and look for “API Error” in each; The instances around the old file which are not in the new file will be the flags where the issue occurred; the lines near those should inform specifically which add-in is the cause.
