Dynamo graph doesn't execute unless zoomed in/out
Hi All,
I’m having some trouble with Dynamo. The problem started when I updated to 1.3.2. It is as follows:
  • The global behavior of the program decreased quite noticeable. When I work in Manual, for the program to run the script or more exactly to DO something I have to scroll the mouse wheel. If not, it stills at “Run Started”.
In the following example is the behavior experienced:
I uninstalled 1.3.2 and got back to 1.3.1 but the problem persisted so I don’t know what to do. By the way, I’m using Revit 2017.2.
I’ll really appreciate if you could help me with this.
Thanks in advance!
This is a developer issue. cc: @Michael_Kirschner2 Please post to https://github.com/DynamoDS/Dynamo/issues
Thanks @Konrad_K_Sobon. Posted!
An update of the issue. The same Dynamo is working just fine in Revit 2016 and Revit 2018. ¿Any Ideas?
Cheers
