Dynamo for Revit 2021
New here. Dynamo version 2.6.1.8850 in Revit 2021 won’t work all of the sudden. It works for my co-worker, same version, same file path locations, nodes, etc.
My graph takes forever to open and then looks like this:
Any idea what is wrong?
Thanks.
I finally realized that Dynamo just won’t work at all in Revit 2021. It wasn’t just that particular file.
It’s almost certainly likely a conflicting add-in. Check to see if there are notes about the conflicts in your Dynamo console (Shift + up arrow in dynamo), Dynamo Log, or Revit Journal files (search for API error).
Alternatively you can disable ALL add-ins and see if that solves the issue. if so add them back in groups until you find the offending tool.
Thanks so much. I will check out the add-ins.
The only conflict I had was with Rhythm, but I found the following post regarding the same issue I had:
All packages were re-downloaded and that resolved the issue, which is what I believe you meant by add-ins. Thanks so much!
I thought by add-ins he was referring to stuff like Enscape and Lightstanza that are extensions inside Revit. These add-ins create their own buttons on the Revit toolbars. Sometimes these Revit additional tools cause problems for Dynamo which was itself an external add-in for Revit, but is now much more integrated into Revit.
Okay, I thought that’s what he was referring to at first, but then thought I misunderstood and that he meant packages. I only have a couple add-ins, and that’s never been a conflict with Dynamo. Thanks for explaining.
I was referring to the Revit add-ins. That is usually an easier test than the packages issue, so I like to start there. Glad you are worked out though. :slight_smile:
I very much appreciate the help!
