Dynamo 2.16 Revit 2023 not opening
Hi, I click to open and Revit just freezes. I’ve done a clean uninstall of Revit. Then it opened a couple times and now its back to just freezing and never opening. Removed packages and still nada.
It finally opened after about 15min. Why is it unbelievably slow with no additional packages installed? Also just super slow to use
Check for conflicting add-ins. API_Error is the flag in your Revit Journal.
0:< API_ERROR { : Assembly version conflict in some references in Autodesk.PnIDModeler.Client assembly
’ 0:< API_ERROR { : Assembly version conflict in some references in Autodesk.EnergyAnalysis.Application.dll assembly
’ 0:< API_ERROR { : Assembly version conflict in some references in DynamoPlayerExtension assembly
’ 0:< API_ERROR { : Assembly version conflict in some references in Microsoft.Practices.Prism assembly
’ 0:< API_ERROR { : Assembly version conflict in some references in Collaborate.dll assembly
’ 0:< API_ERROR { : Assembly version conflict in some references in SkyscraperClientHost.dll assembly
’ 0:< API_ERROR { : Assembly version conflict in some references in DiRoots.One.dll assembly
’ 0:< API_ERROR { : Assembly version conflict in some references in DiRoots.One.Commons assembly
’ 0:< API_ERROR { : Assembly version conflict in some references in DiRoots.One.LanDict assembly
’ 1:< API_ERROR { : Assembly version conflict in some references in Autodesk.C4R.Client assembly
’ 1:< API_ERROR { : Assembly version conflict in some references in Autodesk.JsonApi assembly
’ 1:< API_ERROR { : Assembly version conflict in some references in System.Web.Http assembly
’ 2:< API_ERROR { : Assembly version conflict in some references in Pubnub assembly
25min open and the home page frozen.
dynamoLog_1f32cbc4-f53c-48c5-8596-435a000f53ba.txt (36.8 KB)
Disable ALL your Revit add-ins and see if that fixes things.
Uninstalled DiRoots.one. Not sure what any others are. Well uninstalled any others I know of. Weird everything used to work fine
Open your latest journal and search for ‘vendor is:’.
That should get you an initial list. :slight_smile:
Nothing comes up. All gone
Sorry - Vendor ID. Sometimes autocorrect gets it very wrong.
If not that try vendor.
@vanman Did u see if there’s any Revit update pending, that’s released and you did not update yet??
please see once as i think the latest one is 23.1.30.97
recently i also faced the same issue and this worked for me
Thanks. Getting rid of every add in seems to have fixed it for now.
