Hello everyone the groupbydistance is not working with my version of Python. Any idea to group nearest lines? thank you.
What group by distance node? Assuming it is Python based may have to adjust that code as a first step.
I recall a Node called Group by Parallel Lines (hint)
I don’t have a problem grouping parallel lines. My issue is with grouping by distance. Thank you for your response
“I think I found the solution. I installed the Python 2.7 package and ran the node with that version, and it works now
This is a security issue for many companies. I believe there are a few CVEs which would apply to the underlaying tech (Python 2) if that version was still supported. You would be well served by opening up the custom node, copying out the Python node, converting it to use a supported engine (ideally CPython3), and using that of providing a new DYF/package instead of using the IronPython2 engine.
Hi @hayet.sassi2 i actuelly recommend do these centerlines in acad much easier IMO i just use a lisp.maybe acad has a tool for that inside not sure…, than try with dynamo,can probably work on simple geometry, but if complex, it ill never be fully automated anyway without some really hard sorting where many things can go wrong as well…just me
Hey,
If you want to use CPython3 in a new python node, this code will work…
#Inspired from the "Group Curves" node by Konrad Sobon
# @arch_laboratory, http://archi-lab.net
from Autodesk.DesignScript.Geometry import Geometry
pts = IN[0]
margin = IN[1]
dist1 = Geometry.DistanceTo
Groups, Queue = [], []
while pts:
group = []
Queue.append(pts.pop() )
while Queue:
p1 = Queue.pop()
group.append(p1)
for i in range(len(pts)-1,-1,-1):
if dist1(p1, pts[i]) <= margin:
Queue.append(pts.pop(i) )
Groups.append(group)
OUT = Groups
Hope that helps,
Mark
I noticed you have IFCNodes installed. If you’ve had a chance to try it, I’d love to hear how it’s working for you. No pressure though, just curious.
Hello, thank you. Yes, it’s working thank God for the Dynamo community
other solution with LINQ and serialisation of line orientation
code Python (PythonNet3)
import sys
import System
from System import Array
from System.Collections.Generic import List, IList, Dictionary
clr.AddReference('GeometryColor')
from Modifiers import GeometryColor
clr.AddReference('DSCoreNodes')
import DSCore
from DSCore import Color as DSColor
clr.AddReference('System.Drawing')
import System.Drawing
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
def bi_direction_representation(line):
v1 = line.Direction.Normalized()
v2 = v1.Reverse()
lst_vect = sorted([v1, v2], key = lambda v : (v.X, v.Y, v.Z))
vect_repr = "|".join([f"Vect({v.X:.2f},{v.Y:.2f},{v.Z:.2f})" for v in lst_vect])
return vect_repr.replace("-0.00", "0.00")
def cluster_by_distance(curves):
clusters = []
for c in curves:
for g in clusters:
if any(c.DistanceTo(x) <= TOLER for x in g):
g.Add(c)
break
g = List[DS.Curve]()
g.Add(c)
clusters.append(g)
return List[List[DS.Curve]](clusters)
ds_lines = List[DS.Curve](IN[0])
TOLER = IN[1]
groups = ds_lines.GroupBy[DS.Curve, System.String](System.Func[DS.Curve, System.String](
lambda c : bi_direction_representation(c)))\
.Select(System.Func[System.Object, System.Object](lambda x : cluster_by_distance(x.ToList()) ))\
.SelectMany[System.Object, System.Object](System.Func[System.Object, List[List[DS.Curve]]](lambda p : p ))\
.ToList()
# OPTIONAL check the results adding colors
check_lines_color = []
color_values = System.Enum.GetValues[System.Drawing.KnownColor]()
color_values = [c for idx, c in enumerate(color_values) if 0.5 < System.Drawing.Color.FromKnownColor(c).GetBrightness() < 0.65] * 1000
color_values.reverse()
for group_curves, color_value in zip(groups, color_values):
temp = []
color_to_apply = System.Drawing.Color.FromKnownColor(color_value)
ds_color = DSColor.ByARGB(color_to_apply.R,
color_to_apply.G,
color_to_apply.B,
0)
for line in group_curves:
temp.append(GeometryColor.ByGeometryColor(line, ds_color))
check_lines_color.append(temp)
OUT = check_lines_color #, groups
For the next step, I suggest you use BoundingBox.ByMinimumVolume.
