Group closest parallel lines which are equal in length
Hello dynamobim,
I want to filter or group the parallel lines which are closer and equal in length. i’m unable to find the custom nodes to group them.
i need some help.
Thank you in advance.
Regards,
Rathnakar.
Please show us what you already have
this is what i have done…
i got the parallel lines with equal length.
But,some lines are grouped with lines which are far away & which are equal in length.
i’m unable to group the nearest and equal length.
attached the image with some lines so that u can get what i’m trying to say.
this is way i filtered them.
Thank you.
Regards.
@mrathnakar Please post your .dyn and .rvt
I can image a solution with nodes like this:
Checking if they are both parallel and closer than a given margin.
Because we check each curve with each other we get duplicate groups and we need to use List.UniqueItems.
This could be avoided using a Python script for example implementing a better checking algorithm
An optimized python script to do this would look like this:
from Autodesk.DesignScript.Geometry import Geometry
pts = IN[0]
margin = IN[1]
dist1 = Geometry.DistanceTo
Groups, Queue = [], []
while pts:
	group = []
	Queue.append(pts.pop() )
	while Queue:
		p1 = Queue.pop()
		group.append(p1)
		for i in xrange(len(pts)-1,-1,-1):
			if dist1(p1, pts[i]) <= margin and p1.Direction.IsParallel(pts[i].Direction):
				Queue.append(pts.pop(i) )
	Groups.append(group)
OUT = Groups
Kudos to @Dimitar_Venkov since this is a slightly modified version of the Python code in Springs.GroupByDistance node
