I’ve been tring to build a script to create beams from CAD lines. We are almost finished. I want the dynamo to group the parallel lines and assign the related beams. Added some nodes but it didn’t worked properly.
Here’s how i grouped and where i am having error:
KİRİŞ Açılı Group.dyn (80.6 KB)
VAKKO Bodrum1 Statik.dwg (91.4 KB)
Your group geometry by distance has single lines being returned. Surface by loft requires two lines to create the surface.
So i must use group geometry after surface by loft?
Actually what I responded, may not be correct. I just downloaded and looked at you graph and you have a lot more happening between those two nodes. So it very well could be something else. I don’t have all of the packages loaded to run your script, so unfortunately I can’t troubleshoot any further. Hopefully, someone else can help with the issue.
I have managed to grouped the lines by distance. Script create beams by using all lines not only the ones by grouped by distance. My goal is create different beams after i grouped them by distance.
KİRİŞ Açılı Group.dyn (103.2 KB)
kat1-5 - Kopya.dwg (77.2 KB)
Ok @staylor thank you. Your idea was a start point. It took me one step ahead. Please take a look to last version with the nodes when you have a time.
