Group Parallel lines
hello every one Iam using @DYNAMO v.3.6.1, the node Group parallel lines is not working anymore I tried to use the lines direction and group them by direction everything is fine but I can’t find a solution for ꟿ Geometry.GroupByDistance any help please and thank you in advance.
Hi @hayet.sassi2 maybe something her could work
forum.dyn (16.2 KB)
hello @sovitek thank you for your response but it doesn’t work with my dwg
allright, probably some rounding your vectors then…
the same script is working with another version of Dynamo (less than v3.6.1) probably they didn’t update their package
that python ishared need pythonnet 3 package have you tried that ?
yes I tried it ,get location doesn’t work with dwg I have an error
you cant get dwg lines that way if linked, just use what you try try with bimorph, you are welcome share a small dwg where it doesnt work
